1. DARKinVADER
  3. Sunday, 12 August 2012
i installed J51_Oxygen on J2.5 but Somehow, the hornav menu items overwrites my first menu's (in the sidecol-a position) menuitems. The first menu's title is correct, but the menuitems are coming from the hornav menuitems.
I have another template with completly the same layout positions and setting. That works fine with the same settings.
What coult be the problem? I'm hardly waiting for your answer. Thank you and have a nice day!
Best regards
Gábor
Hi Gábor
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will investigate this issue further.
Thank you for the access.
I have updated your template to the latest version and everything now appears to be working fine.
Thank you for your fast response and support. One last question. Is it possible to have that "dropdown" style menu in the sidecols section like at the top in the hornav section? Thank you again and have a nice day!
  3. # 3
Not included with the template however there is a number of 3rd party extensions available that might be worth considering. Check out.. http://extensions.joomla.org/extensions/structure-a-navigation/menu-systems/accordion-menus
  3. # 4
