1. [email protected]
  3. Friday, 05 August 2022
Hello. I'm using Layla & want to hide items in header-3 module. I've set this to hide in responsive options on the template general page, but they are still visible. If I set showcase to hide, this does work. Could you suggest what I've done wrong please?
On which Joomla version are you having this issue? Would you have a URL to an example of your header-3 module where the issue is present?
Hello. I've recenty downloaded the Joomla 4 version of the template, this is the development address;
https://gtts-four.cloudaccess.host/
Viewig on an Apple 12 mini, I still see the content for this module, which I would like to hide.
Hi Keith
To amend try adding the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
.header-3 {
display: none;
That's done the trick, many thanks.
