1. Romeo
  3. Tuesday, 25 August 2015
is it possible to hide the main container on the starting page? But only there...
I would like to have just the background image, the logo and main menu to be displayed.
2nd: How can I change the default position of the logo & menu while keeping the same size of the bg-image?
thanks for help,
Romeo
Hi Romeo
1. May I suggest the following forum post on this query... http://www.joomla51.com/tutorials/item/hiding-the-component-article-area-on-a-page
2. Would you have a URL to an example of your logo and details on how you wish to edit it's position?
Hi ciaran,
thanks for support.
Please have a look at
http://87.106.243.239/vin/index.php/de/
to see what I mean.
Page is under construction. So the credentials for accessing the frontend are:
user: romeo
pass: cyx56789
your advice:
#container_main {
display: none;
didn't work because it left the black margins on top and button of the box.
Also I want the logo bar with language switcher to be displayed a little bit higher on the page.
Thank you for your help.
regards,
Romeo
finally I have found that
#container_main {
display: none;
.content_background {
display: none;
worked out.
Now I have a clear starting page.
But how can I move the logo and main_menu bar a little more upward?
Thank you,
Romeo
Hi Romeo
To amend try adding the following to the Custom CSS field of your templates parameters where 200px is the height above your logo area (edit to taste)...
.container_spacer2 {
height: 200px;
Hi ciaran,
it's fine that way. But now the bg_image is cut off.
How can the bg be displayed in total.
thanks,
Romeo
To increase the header space to display more of your background image try increasing the 'Header Vertical Spacing' field in your templates parameters.
Changed it from 250 to 500... no change.
Hi Romeo
Looks like to achieve this you will need to give the div above the header and the div below the header unique class names. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will make this amendment for you. For our reference please paste a link to this post in your email.
You can now edit your top and bottom header spacing with the following which has already been add to your Custom CSS field (edit to taste)..
.header-top {height: 50px;}
.header-bottom {height: 350px;}
Hi Ciarán,
works out fine. Thank you for adjusting the template.
best regards,
Romeo
