1. ivavia
  3. Tuesday, 15 September 2015
Hello, I'm working on my new website based on Stockholm template:
http://udruga-portic.hr/crcke3/index.php
Can you help me to make my background image scroll down as long as the main content is displayed?
As you can see here - http://udruga-portic.hr/crcke3/index.php/typography
after a while, the background image is replaced with white area.
Also, back to the home page, is it possible to make the gap between modules smaller?
Detailed explanation in the attachment photo.
Thank you.
Thank you very much!
To remove try adding the following to the Custom CSS field of your templates parameters...
.bottom-1 .module:first-of-type .module_surround {
    padding-top: 0;
If it's not too much, please help with one more gap.
I need to reduce it as well. Thanks in advance.
Thank you, it worked like a charm :)
Hi Ivavia
To reduce the spacing between your logo and slideshow try using the following custom CSS...
#container_slideshow {
    margin-top: -30px;
Note: Adding CSS to the Custom CSS field will only apply to that template style. Adding to the nexus.css will apply to all template styles.
Thanks for your response.
I resolved the first issue but not by adding your code in Custom CSS file, it worked only when I added it in template/nexus.css.
The other one worked well.
But there's still a gap between logo / main menu modules and showcase module...
Any idea?
To resolve try adding the following to the Custom CSS field of your templates parameters...
#body_bg {
    background-position: 50% 50% !important;
To reduce the indicated gap you can also include the following to the same Custom CSS field...
.top-2 .module .module_surround {
    padding-bottom: 0 !important;
