Is there any new version for this module with module suffix?? Can i write some code in order to put a style on it???
THANKS
<config>
<fields name="params" addfieldpath="/modules/mod_j51hover/php">
<fieldset name="Advanced">
<field name="hover_title" type="text" default="Your Image Title" label="Hover Title" description="Enter your Hover Title" />
<field name="hover_description" type="textarea" default="Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor." label="Enter text description" description="" rows="4" cols="30" />
<field name="textcolor" type="jscolor" default="#FFFFFF" label="Text color" description="Select the color for your Text" />
<field name="style" type="folderlist" hide_none="true" default="FallIn" label="Select Style" directory="modules/mod_j51hover/css/" filter="" exclude="_navigator|_contentslider" stripext="" />
<field name="Directory" type="media" default = "images/1.jpg" label="Image Directory" description = "Image Directory" size="30" />
<field name="pxHeight" type="text" default = "200" label="Heigth in pixels" description = "Heigth in pixels" size="10" />
<field name="pxWidth" type="text" default = "200" label="Width in pixels" description = "Width in pixels" size="10" />
<field name="hover_link" type="text" default = "http://www.joomla51.com" label="URL Link" description = "URL Link" size="30" />
<field name="bgcolor" type="jscolor" default="#006699" label="Background color" description="Select the color for your Background" />
<field name="HOpacity" type="text" default = "0.7" label="Color Opacity 0.0 -> 1.0" description = "Hover Opacity"/>
</fieldset>
</fields>
</config> <config>
</fieldset>
<fieldset name="advanced">
<field name="moduleclass_sfx" type="text" default="" label="Module Class Suffix" description="A suffix to be applied to the css class of the module (table.moduletable), this allows individual module styling" />
<field name="cache" type="list" default="1" label="Caching" description="Select whether to cache the content of this module">
<option value="1">Use global</option>
<option value="0">No caching</option>
</field>
<field name="cache_time" type="text" default="900" label="Cache Time" description="The time before the module is recached" />
</fieldset>
</fields>
</config>
