1. ziggy
  4. Tuesday, 16 April 2013
Having bought the 'Clarity' template, I wish to change the position of top bar & menu - instead of a header and menu at top, then both placed at bottom! A modified template - clarity2! Otherwise same styling!
Does joomla51 adjust their templates for a fee? I will be glad to forward details!
Regards..
Andreas
Hi Andreas
Sorry to say at present this is a service we do not provide.
To point you in the right direction make these amendmends you can open the templates index.php (../templates/j51_clarity/index.php)..
<div id="container_header" class="container"><div class="wrapper960">
<?php require("php/layouts/header.php"); ?>
</div></div>
<div id="container_spacer1" class="container"><div class="wrapper960">
<div class="clear"></div>
</div></div>
<div id="container_hornav_mobile" class="container"><div class="wrapper960">
<?php require("php/layouts/hornav_mobile.php"); ?>
</div></div>
You can try moving this further down the page directly after <?php require("php/layouts/base.php";); ?>
