1. [email protected]
  3. Tuesday, 22 May 2018
Good evening.
I bought your Harmony template for my site http://www.fomet.it.
My problem is in the header: if I reduce the width of the browser, so to simulate a mobile device, I see there is a lot of blank space just below the header, as you can see in the image attached.
How can I remove all that blank space?
Thank you.
Mattia
  1. http://www.fomet.it
Hi Mattia
#container_header {
height: auto !important;
min-height: auto !important;
padding-top: 35%;
Hi Ciarán,
your solution is very good, thank you!
The problem now is it works only for width under 1024px, I think.
Is it possibile to make it work for every width? I tried to remove the line "@media...", but doing so the menu bar goes below the header and I don't want this behavior.
Thank you very much
Mattia
So you tried the following?...
#container_header {
padding-top: 35%;
Would you have a screenshot of the issue it creates?
Good morning Ciarán.
In the attached screenshots you can see the position of the menu: "Before.png" shows the desired position (it is the current position), "After.png" shows the position after removing the line from css.
Massimo
Does changing the suggested custom CSS to the following resolve the issue?...
#container_header {
padding-bottom: 35%;
This works very well!
Massimo
