1. Hemingray
  3. Wednesday, 12 September 2018
I recently bought the Hayley template and have uploaded it to https://ecclesiasticallawassociation.org.uk/index.php. I would appreciate advice on two issues:
(1) I want to have 'Ecclesiastical Law Association' under the logo. Although I have entered some slogan text, it does not appear.
(2) The top menu appears not to be responsive. Can it be made responsive? I was hoping that, when the site is viewed on on a phone, therfe would be a hamburger menu to replace the horizontal menu, but cannot see if that is possible.
Ray
  1. https://ecclesiasticallawassociation.org.uk/index.php.
Hi Ray
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine both of these issues further. For our reference please paste a link to this post in your email.
Ciaran, thank you for your reply. I have solved the menu issue. I had entered a break-point that was too small.
But I still can't solve the slogan issue. I will send you temporary access details, as requested.
Many thanks.
Ray
Thank you Ray
Could I ask you to allow us access to your template file editor (Extensions -> Templates -> Templates -> [YourTemplate) so we can edit template files.
Dear Ciaran,
I emailed a username and password to [email protected] yesterday at 2.30pm, as I did not want to put the details in a posting that anyone could see. Have you received the email. If not, please call me on 01733 262523, and I will give you the details.
Regards.
Ray
Hi Ray
Yes we received your details. It allows us access to your Joomla administration but not to the template editor within the admin (Extensions -> Templates -> Templates -> [YourTemplate]). For this we would require 'Super User' status.
