1. Bergfotograf
  3. Tuesday, 09 May 2023
have a problem with the template Hayley. If I want to insert a gallery, for example, in the frontend in the editor via a button, the open window is greyed out. Access to the window is not possible. Only a refresh solves the problem.
With the standard template Cassiopeia, everything works as usual.
Is this an override problem?
It is unlikely to be an override however there could be some clashing CSS that is causing this issue. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
THis issue appears to be now resolved with the addition of the following CSS to your template style custom CSS field..
.modal-open .slideout-panel {
position: initial;
it works. Many Thanks to you
Addition: The template Maya for Joomla 4 has the same problem. I have fixed it with the code.
