MENU
  1. Turkenburg
  4. Sunday, 08 December 2019
In Fire Fox the menu works fine but in Safari and other browsers the menu empties itself after 1 second.
How to fix this?
Best regards, Wouter
  1. https://www.ijscluboegstgeest.nl
Hi Wouter
Unfortunately, we are unable to replicate this issue. May I ask on which other browsers you are having this issue?
On Safari. It works fine on FireFox it seems to work. How come?
Wouter
Wouter
Hi Wouter
May I ask on what version of Safari are you having this issue?
I am using Safari 13.0.2 (version 2013-2019). I see there is Safari 13.0.3 but the reviews are not that good.
Other users have the same problem with Safari but not with other browsers.
I have various J51 templates. It looks like the other ones do not have this issue with Safari. Is this correct?
Thanks for your help,
Wouter
Is the issue present if the header image is disabled?
Yes, the issue is still there, even if there is no header image.
Wouter
Do you find the same issue with the template demo (https://www.joomla51.com/demo/0145/)?
Your site has a JS console errors related to a 'weerwidgets' extension. Does disabling this extension help?
CIaran
Dear Ciaran/Claran,
The demo looks fine: no problem there.
I have disabled the 'weerwidget' The problem is still there.
Fine in Firefox, not good in Safari.
If you have any clue, please let me know.
Kind regards, Wouter
I'm having the same issue using Safari on Mac. Noticed this for a couple months now.
Entire menu disappears on mouseover. Does the same in your demo.
Safari Version 13.1.2
Mobile menu works fine.
Thanks,
Mark
