1. wallis
  4. Monday, 03 July 2017
I’m dealing with an error in Hannah template: the Module Bottom 3 behaves erroneously. I need this module because is this website I used all the available horizontal modules down do the bottom. When searching for alternatives to this erroneous module, namely Module Base 1 and base 2, I discover some idiosyncrasies in Hannah’s template settings:
1. In “Styling” is not possible to assign background adjustments to Base 1 and Base 2 individually.
2. In “Module Style Overrides” there is no option for Bottom 2 f and for Base 1, a to f and base 2, a to f.
Because it is not possible to use module base 1 separated from module base 2 (unless we can use the same settings, which I cannot) I have to insist in using module Bottom 3 since there are no others available. The error description is this:
I have created 3 custom modules for Bottom 3A, Bottom 3B and Bottom 3C. In the template settings I used the normal methodology: in “Module Widths” I enabled manual and for the values I set 33.3% for each and 0 for the others. The visualization is erroneous. I made several tests, one was disabling the manual widths: the modules show correctly but the effect is bad in mobile size. If I use those custom modules in bottom 2 they show correctly (but I need bottom 2 for something else).
I provide the website link bellow.
Can you help?
  1. http://www.agrupamento-alfredodasilva-sintra.pt/novo3/
