1. EFH
  4. Thursday, 12 February 2015
Hi there,
How do I adjust the width and height of the images for gridgallery in responsive mode for mobile landscape?
It is not displaying correctly. This is the url, pls check on mobile landscape.
http://www.justweddingentertainment.com.au/joom3/index.php/entertainers/sydney
Try adding the following to the Custom CSS field of your templates parameters, this should disable the height you have set on smaller screen devices.
.j51gridgallery figure {
    height: auto;
Hi there,
I have tried the below code in the custom ccs field but it does not work for mobile responsive.
I have attached an image.
We are unable to see the suggested CSS in your source. Presuming you want all images of equal height your best option would be to resize all your to have the same dimensions. You can then remove any related Custom CSS which will resolve this issue.
That's Perfect!!
Thank you.
