Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. Carrie Wrigley
  3. Monday, 23 March 2015
Ciaran, how can I get the icon with the login module to display white rather than grey? All the other button text etc is white - not sure where this grey came from. See it here:
http://impactmusic4kids.org/about-1/contact
Specifically - it looks like the outline is white, but the fill is grey, and needs to be turned to white. Your advice?
Hi Carrie
To amend could you try adding the following to the Custom CSS field of your templates parameters, where #FFFFFF is your new icon color...
.input-append .add-on, .input-prepend .add-on {
color: #fff;
text-shadow: none;
Another elegant and effective solution. Totally fixed it. Thank you!
