1. Bears98
  3. Wednesday, 06 April 2022
I am not able to do front end editing using CE nor tiny editor. It shows after logging in correctly a button for editing (Layla sc1), but when I click it, the complete textarea disappers (Layla sc2). I updated to the new version 1.1.1 (march 10th).
Thanks in advance
Winfried
Hi Winfried
Thank you Windfried. However, the URL provided appears to be giving us a 404 not found error.
To resolve your issue, could you try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.modal.hide {display: none}
.tab-pane {display: block;}
H Ciaran,
thanks comoing back, but your proposed solution did not solve it.
I corrected the URL and sent e-mail again,
Winfried
Hi Winfried
Could I ask you to resend your email as we do not appear to have received it. Alternatively, you can private message me via the forum at following URL https://www.joomla51.com/forum/profile/264-ciaran (chat icon under subscribe.
done
Winfrie
Thank you Winfried
I can now replicate your issue. It seems that the entire markup of the component area of your template is been removed from the dom. This is most likely caused by a plugin conflict. Could I ask you to allow us access to your template editor and we will try finding a fix for this issue.
I discussed wiht the customer, he can use also the backend to access the articles. Thanks for the help so far
Winfried
