1. machart25
  3. Monday, 11 September 2023
Hello, I have the annoying problem again with the error message Duplicate entry '700-4.3.0-2023-03-29' for key 'PRIMARY'. This time with the Stockholm Template J4. Is there any solution ciaran?
Thank you so much!
I have just updated to the latest Joomla version and rebuilt the demo installer for the Stockholm template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Wow! Thanks for the quick reply and solution to the problem! Its working. :D
Hi Ciaran, today I tried to install the creative template. The error “Duplicate entry ... for key “PRIMARY”” is also thrown.
Can you fix it too? Thank you very much!
I have just updated the Creative demo isntaller to the latest Joomla version and rebuilt the demo installer for the Stockholm template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
thanks for the fast reply. The Duplicate-entry-Problem ist solved so far. Now the error JLIB_INSTALLER_ABORT_REFRESH_MANIFEST_CACHE is thrown for mod_j51layerslideshow. Whats up with the module?
Kind regards, Nadine.
Hi Nadine
I tried it many times, on several Servers: its not possible to install the demo installer of creative.
There must be an email in your inbox.
Nadine.
