1. Ketchup
  3. Tuesday, 20 August 2019
I need help with footer menu and bottom module positions in Revolve template.
On the website florbalrokycany.cz is module "for example" on the position bottom1-a and on the main site doesnt work and on the other sites yes,
When you look to the http://florbalrokycany.cz/jarni-florbalovy-pochodak-2019 , you can see that the module "for example" is working properly. On the home page, module "for example" doesn´t work at all bottom positions, but on the top possitions it does.
I tried to change the template because I'm using a different setting on the home page, but it didn't help.
And at the bottom of the page is a gray bar that covers the footermenu, and it seems to me that these two things might have something in common, because on the other pages it is not.
thank you very much
May I ask, does disabling the LayerSlideshow module on your homepage resolve the issue?
no disabling the LayerSlideshow module does not help. Even if I disable the position container_base there is still a gray belt down and the menu is not visible.
Jan
Hi Jan
CIaran
