1. ballantyne
  3. Friday, 19 September 2014
Renovate and Enlighten
Is it possible to put a different menu in the footer or the base positions which display horizontally?
Great templates, thank you
Evelyn
Hi Evelyn
Could you forward us a link to your menu in the base or footer module positions and we will put together the needed CSS for you.
Ensure that no other module is published along side your menu.
Thank you Ciaran
I have attached a word doc showing the bottom of the site page.
It seems both Renovate and Enlighten repeat the hornav in the footer.
I particularly like the animate on scroll in enlighten, thank you.
example on devongraphics.com
Evelyn
Hi Evelyn
The footer menu at the very bottom of yoru page is controled from within your templates parameters under the 'Menus' tab.
For us to create the CSS for a horizontal menu in the base-## module positions please ensure that no other module is published along side your menu.
I have taken out other modules from the base position and left the menu I would like to display horizontal.
Evelyn
Try adding the following to the Custom CSS field of your templates parameters...
.base-2 ul.menu li {
float: left;
padding: 5px 20px 5px 0;
Note that you will have to disable 'Manual Widths' in your templates parameters so your module spans the full width of your template.
Dear Ciaran
Thank you so much. You have been very helpful and it is very much appreciated.
Kindest regards
Evelyn
