1. ukfish1
  4. Wednesday, 06 February 2019
Is it possible to use the font "Aileron" in the Kaylee template?
Thanks, Paul
Hi Paul
Presuming this is a non-Google font you will have to add the font manually.
Firstly upload your font files to the ../templates/[YourTemplate]/fonts folder.
Then to actually import these files you can add the following to the Custom CSS field of your templates parameters..
@font-face {
font-family: 'YourFont';
src: url('../fonts/yourfont-webfont.eot');
src: url('../fonts/yourfont-webfont.eot') format('embedded-opentype'), url('../fonts/yourfont-webfont.woff2') format('woff2'), url('../fonts/yourfont-webfont.woff') format('woff'), url('../fonts/yourfont-webfont.ttf') format('truetype'), url('../fonts/yourfont-webfont.svg') format('svg');
font-weight: normal;
font-style: normal;
Once your fonts are loaded you must then assign the font to the HTML elements of your choice with something like the following (Custom CSS field)...
body {
font-family: YourFont;
Thanks but can’t seem to get it to work.
I have added the otf file to the template fonts folder and added teh following to custom css.
@font-face {
font-family: 'Aileron-Regular';
src: url('../fonts/Aileron-Regular.otf');
src: url('../fonts/Aileron-Regular.otf') format('embedded-opentype')}
font-style: normal;
body {
font-family: Aileron-Regular;
Still shows Saira Condensed ads the default font.
paul
aira Condensed
Hi Paul
Have you uploaded your font to the font folder in your template directory? Would you have a URL to an example of the issue?
This is the path of the font:
http://www.west5web-trial.co.uk/templates/j51_kaylee/fonts/Aileron-Regular.otf
The font should be displaying in the body at http://www.west5web-trial.co.uk/about-us
Thanks, Paul
Hi Paul
I notice a slight syntax error with your CSS. Replace your font loading with the following...
@font-face {
src: url('../fonts/Aileron-Regular.otf') format('embedded-opentype');
font-style: normal;
