1. [email protected]
  3. Monday, 14 February 2022
I have a problem with the Novah template and the display of icons (fontawesome) in the CPanel of HikaShop. Some icons are invisible. See attached. I contacted HikaShop tech support who told me this:
Your issue come from your template that use the fontawesome 4.7, but HikaShop use the fontawesome 5, and so if your template override the Fontawesome 5, then that's why some icon disappears because they are not compatible with the oldest fontawesome 4.
Your solution is to contact your template creator to make him switch for a most recent fontawsome, sorry for this return but on our side we can't say much more.
Hope this will help you to solve your issue.
Can you tell me how to fix the error
To use FA5 you can try the following...
1. Disable Font Awesome in the General -> Typography tab of your template settings.
2. Add the following to the Custom Code -> Head Custom Code field...
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.15.1/css/all.css">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.15.1/css/v4-shims.css">
thanks for you answer but i still have some icons that do not appear (see screenshot)
Best regards.
Maybe (the developer here) could help a link to your problem...
How can send you the access code of back-office ?
Have you an email adress ?
i send you a private message.
Hello, have the same Problem!
