1. drbenjaminfranz
  3. Monday, 08 March 2021
is there a way to make the Font Awesome icons display to the left of the attached text as opposed to above it? I cannot seem to find such an option.
Thank you in advance!
Would you have a URL to an example of your text/icons?
Can I email it to you as I am a bit embarrassed of how ugly my page currently is?
Benjamin
Hi Benjamin
Sure. Details can be sent to [email protected]. For our reference please paste a link to this post in your email.
I believe I misunderstood what you were asking. I would like to have a number of symptoms with a check mark that precedes them much like the link below.
https://ocspinalcare.com/
I am using the module with the fontawesome icons "Check mark." I can display the text with a check mark. Whether I have the text tagged as left, center, or right, the text always falls below the icon rather than the icon being in front and inline with the text.
I hope this makes sense, and any help would be greatly appreciated
Thank you,
Benjamin.
Hi Benjamin
One possible cause is that your text is wrapped in a paragraph tag. May I suggest trying a span tag instead.
Eg.
<i class="fa fa-check" aria-hidden="true"></i> <span>Your Text</span>
The above works in a custom module and elsewhere, but is there a way to implement the same idea in the J51_icons module?
Depending on your version of the Icons module, you should have an option to set the icon/text in a row via the General Settings -> Icon/Text Layout option of your modules settings.
