1. jascanio
  4. Thursday, 24 March 2016
I use Impact font for my H(n) labels, setting it from within the template styling parameters.
Everything is fine in a PC. But when accessing the web from an Android device (either tablet or mobile) I get another font instead. I've tried both with Chrome and the built-in Android navigator.
I've not tried on iOS devices.
You can reach my web here
As the web is under construction I've set usr & pwd.
These are the details:
usr: vendohielo
pwd: tumandas
Can you help with this issue please?
Thanks in advance
Regards,
Juan
Hi Juan
Sorry to say the 'Impact' font is not installed on Android devices by default. A common alternative is the 'Oswald' font which can be selected from within your templates parameters.
Hi Ciarán,
Thanks for your reply. Oswald is in fact quite close to Impact. However its rendered light. Is there a way to make it bold?
Thanks in advance.
Regards,
Juan
Forget it and sorry to ask prematurely.
I've been searching around and trying, and found that applying the following code will do.
h1, h2, h3, h4, h5, h6 {font-weight: 700;}
.item-title {font-weight: 700;}
Don't know if this is the best solution, but it works. Just posted it here in case it's not or, if it is, others can use it.
Regards,
Juan
Perfect!
Thank you for the update and for posting your solution :)
Thank you too!
Regards,
Juan
