1. kleinpeter
  4. Monday, 08 January 2018
Hi Ciarán!
I've found some old posts about this issue, it might be you have a quick solution at hand :)
It's about the ImageLinkHover (version 1.0 - December 2011) that came with the Clarity Template. I also would like to be able to use External URL's linking to Facbook & Instragram. Currently I'm only able to link to menu items. I've tried to link to a menu item with an external URL in it, didn't work...
Any help would be welkom!
Regards,
Robert
Hi Robert
In your modules modules mod_j51imagelinkhover.xml (../modules/mod_j51imagelinkhover/mod_j51imagelinkhover.xml) try replacing the following...
<field name="hover_link" type="menuitem" default="45" label="Select a menu item" description="Select a menu item to link to." published="1"></field>
With..
<field name="hover_link" type="text" default="" label="Set URL" description="Set the URL to link to." published="1"></field>
This will add a URL field to your modules parameters in which you can set a URL to link to rather than selecting a menu item from a dropdown menu.
As well as the above edit to the XML also edit the following in your modules mod_j51imagelinkhover.php (../modules/mod_j51imagelinkhover/mod_j51imagelinkhover.php)
Replace every instance of...
<?php echo JRoute::_("index.php?Itemid={$hover_link}") ?>
With...
<?php echo $hover_link; ?>
It's OK I fixed it.. forgot to close the code on the .xml file
thx
Hi!
Thank you! I'll try that :D
Cheers,
Robert
  3. # 3
I completed the task and the php file only had one of the type of code available. I am receiving an error message "An error has occurred.
500 Error loading form file" This is for privilege
  3. # 4
