1. cmaj
  3. Tuesday, 20 August 2013
I changed a template (Executive) width. It was 960px, I set 1080 px.
After that I opened my site by iPhone and I found that the right corner of the top menu background is absent. Please look at the picture in the attachment, I have identified the problem areas with a red square.
I saw this effect on iPhone only.
Best regards, Alexander
The URL is: http://music-theory.ru/j25/index.php?lang=ru
I have found the bottom gray line is cut too (see attachment)
But if the template width is 960px - OK
Hi Alexander
#container_header, #container_base {width: 100% !important;}
Hi Ciarán
I have made it but I haven't seen changes.
My idea is:
I'll try to make a vertical line (width 1px) form your 'header.png' picture and change CSS for #container_header:
background: url(<here_vertical_line>;) repeat-x;
If it works I will make the same action for #container_base.
I'll try it today evening or tomorrow and write your results.
Hi Ciarán
I made a vertical lines from the 'header.png' and 'content_base.png' files width 1px. Names of new files and names of old files are same ('header.png' and 'content_base.png').
After that I changed CSS (nexus.css), see the 'backrgound' tag:
#container_header {
/*background: url(../images/header.png) 50% 0 no-repeat;*/
background: url(../images/header.png) 0 60% repeat-x;
height:160px;
z-index:20;
margin-top:5px;
But I have not seen any changes on my site: If I open the site by computer I will see a correct page.
But iPhone shows an incorrect page still. May be is it cache of iPhone? I have cleared a cache...
It's very interesting what the reason of the problem is :)
Ciarán, I hope I have not tired you with the problem. Sorry, but I really can not solve it myself.
Hi Alexander
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email
Hi Ciarán
I have sent login & password by email
Thank you Alexander
I have added the following to the Custom CSS field of your templates parameters which has hopefully resolved the issue...
@media only screen and (max-width: 1080px) {
#container_header, #container_base {width: 1080px !important;}
Hi Ciarán
Thank you very much for your help! It works fine! :)
p.s.:Maybe you have seen in the list of templates I've tried other templates (not joomla51.com). Your templates are the best templates I've ever seen :) Really professional work, thank you! :)
