1. [email protected]
  3. Wednesday, 29 October 2014
Was wondering how to separate different sidecol B modules so there is a gap in-between them that has background fill in it. I have used the Metropolis template and this was standard so I was wondering what CSS I need to change?
Regards,
Matt
Hi Matt
Would you have a URL to an example of your modules?
Link to site:
http://www.knowitall.co.za
The modules in Sidecol B need to have a gap in-between them (Testimonials and Upcoming courses) so they are two independent blue blocks.
This is a metropolis template I used and you can see each side col module is a separate block?
http://www.modelaclubofsouthafrica.com
I was wondering if this is possilbe?
The area in blue is the containing div of all your modules in the sidecol-b module position, it therefore for would not really be possible to split the div. One option may be to add a background to the inside module div with something like the following...
#sidecol_b .module {
background-color: rgba(255, 255, 255, 0.2);
margin-bottom: 10px;
Thank you so much! Your support and willingness to help is really why I love your templates.
That was my error it seems. Thanks again!
