1. judemac
  3. Tuesday, 05 February 2013
Hi.
Is it possible to swap the search module above showcase with a Google language translator? I would also like to remove the footer menu as I have no need of it and it makes my footer look messy.
I have looked to see if the above are in set module positions, but can't find them if they are?
Thanks,
J
Hi J
May I suggest the following post which details how to convert the search are of your template to a module position.. http://joomla51.com/forum/support/commercial-templates/j51-rendezvous-custom-module-in-hornav-or-sear#498
You'll find the position won't be listed in the positions dropdown so simply type it in to create (search).
Worked a treat :)
