1. jflash
  3. Friday, 27 January 2023
Hello!
I want to change FontAwesome icons, but not all appears what i choose. Where i can see what icons i can use? In view of a attached image i use icins:
fas fa-pencil-alt
fas fa-hammer
fas fa-truck
fas fa-screwdriver
Only truck works.
this:?
https://fontawesome.com/v4/icons/
.... but too old, i need more...
I do not understand that. too old ?
that's well over 1000 pieces. too little?
When you open the J51_icons module, under the tab: "Icon settings" there is a choice of 6 links how to find icons ? there must be something there?
Which Joomla version are you currently using? It is worth noting that Joomla 3 core loads Font Awesome 4. With Joomla 4 you will have Font Awesome 5 which has a considerable increase in icons available to you.
this:?
OK, working, but too old, i need more...
