1. jascanio
  4. Tuesday, 02 July 2019
I use the component Community Polls, by CoreJoomla in my web.
When I access this component from the frontend all the dropdown submenus' height shrink. Apparently there must some sort of reduction in height. I've been inspecting this behaviour but cannot reach a clear conclusion.
Could you please help me with this?
Should you consider this is a component's bug (which is likely), please do not hesitate to tell me, and I will contact them.
I include url to affected section in the web. Please browse to any other menu item to see dropdown menus displayed normally.
Thanks in advance for your reply.
Regards,
Juan
  1. http://latadeje-cp374.webjoomla.es/en/participation/your-opinion
Hi Juan
I am unable to locate an example of a component dropdown. I only available when logged in, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi CiarĂ¡n,
Thanks for your reply.
I attach images.
I also see that at the base position module contents are also shrinked
I've just sent you temporary admin details in case you need them.
Kind regards,
Juan
Thank you Juan for detailing.
To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS). Your menu dropdown item height should then remain consitent across all pages.
.hornav li {
line-height: 2em;
Thanks for your help.
Problem solved
Regards,
Juan
