1. ellector
  3. Monday, 09 October 2023
I have purchased and installed your template. And all I get is a 500 error
BEHAVIOR:: CAPTION NOT FOUND
I don't know what I am doing wrong.
I have seen in the forum some similar error. I see that you seem to indicate a script, but I don't know in which file it has to be inserted and if the error is the same.
Thank you very much in advance
Carles Codina
  1. http://www.ellector.com
It appears your template overrides are not getting updated. To amend, could you try deleting your template html folder (../templates/J51_skylar/html and then re-installing the template.
If this does not resolve the issue, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi Carles,
I had the following problem with SKYLAR_J4: In the J3 version, I had used class "caption" to get (formatted) captions under my pictures. In the J4 version, this didn't work. To solve the problem, Ciaran privided me with the following scripf:
<script>
document.addEventListener("DOMContentLoaded", function() {
const imgs = document.querySelectorAll(".maincontent img.caption");
for (const img of imgs) {
const caption = document.createElement("p");
caption.classList.add("img_caption");
caption.innerText = img.getAttribute("title");
img.after(caption);
</script>
This script has to be placed here:
I'm not quite sure whether this helps.
Rolf
