1. Frittola
  3. Thursday, 10 March 2022
i buyed the Esley Template for Joomla 4.1.
After switch it to the Template is not working. The Standart template "Cassiopeia - Default" works
Can you help me to fix this issue?
Hi there,
can I join this post. Got the same issue.
With a clean Joomla 4.1.0 Installation and 4.x Version of Ensley Template i get the error:
0 There is no "template.slideout" asset of a "script" type in the registry.
Herbert
Thank you Herbert
We have just updated the Ensley template, resolving this issue. It seems an error was introduced with the adding of child template support yesterday.
Updating your template to the latest download should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
Hello and thank you for help. Its working now, but i have Problems with the icon library not working
Please detail in what way the icons module is not working for you.
Please have a look at headers position:
http://kraus.6227788441700.hostingkunde.de/de/
Assuming you wish your icons to display similar to your text. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.header-2 i {
color: white;
font-size: 16px;
i try this but is not working!
Try replacing with...
.header-2 i::before {
color: white;
font-size: 16px;
The Color is working but the Icon not
Are you referring to the icon size?
I mean you can't see the icon, there's only a square to see
Following is how we see your template header with icons for both your email and phone number. Are these the icons you are referring to?
Hello, no symbols appear for me see picture ...
On what browser are you having this issue? Is the issue present on all browsers (Chrome, Firefox etc.)?
Hy, this is Edge Browser. it sees to be a Browser Problem.....
i Have testet chrome, firefox and egde. All the same result...
We have tested in Edge with the same result. Icons are displaying without issue. Does adding the following to the Custom Code -> Custom Head Code field of your template settings resolve the issue?...
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/5.15.4/css/all.min.css" integrity="sha512-1ycn6IcaQQ40/MKBW2W4Rhis/DbILU74C1vSrLJxCq57o941Ym01SwNsOMqvEBFlcgUa6xLiPY/NS5R+E6ztJQ==" crossorigin="anonymous" referrerpolicy="no-referrer" />
unfortunately it doesn't change anything
I notice your icons are using the older FA4 syntax. Joomla 4 is now using Font Awesome 5. Does changing your icon markup for your envelope for example to the following resolve the issue?
<i class="fas fa-envelope"></i>
  • 2
