1. nivento
  3. Friday, 17 October 2014
Hi, i have buy this beautiful template but i have two problems.
Looking the site from the top of the horizontal scroll bar appears.
http://www.simonezagagnoni.it/caritas
I would then remove the menu from the bottom of the page.
I would also add, that to achieve the banner WIDGETKIT use and do not understand why it has good visibility on the homepage and other pages show me only the first slide.
Thanks for your help.
Simone
Hi SImone
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine these issues further. For our reference please paste a link to this post in your email.
Hi Simone
I believe this issue to be related to th 'contact' dropdown menu. Although we do not see the scroll bar here, if your screen size is small enough the dropdown will cause a scroll bar to appear as it is outside of the viewport (browser window). To amend try chaing the position of the contact menu item so it is not at the very edge.
To hide the footer menu try adding the following to the Custom CSS field of your templates parameters...
#footermenu {
display: none;
I dont believe the Widgetkit issue to be related to the template. It appears Widgetkit is looking for your images in the root (/images/banners/banner1.jpg) rather than in the caritas folder (/caritas/images/banners/banner2.jpg).
I solved everything for the footer.
Regarding the widgetkit not.
In this component from a path and he draws the picture there, wherever it is.
In this case the generic folder / images / banners
So the problem is not the widgetkit, you have other ideas?
As for the menu, I get it, I will find a solution for managing menu items.
You appear to have fixed the widgetkit issue? Your slideshow appears to be now working on each page.
