MENU
  1. ullidalli
  3. Tuesday, 07 October 2014
page works fine on mobile devices except for this:
When you go to the mobile menu, there is a menupoint called "Kernekompetencer". This opens but there is a problem with the first point on that menu:
http://www.dan-expo-oversaettelse.dk/oversaettelsesbureau/oversaettelse-hjemmeside.html
The menu point/link shows up, but when you click it, nothing happens = the article does not load.
This is the only menu point which has a submenu, namely this one:
http://www.dan-expo-oversaettelse.dk/oversaettelsesbureau/oversaettelse-hjemmeside/seo.html
When clicked that page loads fine.
Frankly, I am baffled - this happens on all mobile devices, both phones and notepads, android and apple.
It works fine on the computer, i.e. http://www.dan-expo-oversaettelse.dk/oversaettelsesbureau/oversaettelse-hjemmeside.html loads/shows.
The other two menupoints (with no submenu) work fine.
Can you help or is this a Joomla thing?
Best regards
Bodil
Hi Bodil
May I suggest converting the parent menu item to a 'Text Separator'. From your Joomla administration navigate to Menus -> [Your Menu] -> Kernekompetencer and set the menu item to System Links -> Text Separator.
Issues can arise with the mobile menu if the top menu is a link.
Hi Ciarán,
Thanks for the speedy reply.
Tried it, but it doesn´t solve the problem.
The reason I didn´t use a text separator in the first place is you can´t add a CSS style (font awesome) to the link (as far as I can see). Just can´t win :)
However, there does seem to be some problems with External links in Joomla 3, spent a jolly hour on Sunday afternoon because the date got added to the urls under "Refences" which is also an external link. I had set it up exactly the same as "Kernekompetencer". Fortunately I found a solution in a Joomla forum. So there.
I´ll leave it as it is, discovered that you can actually access the page if you press the link via the subpage. Not ideal, but I can live with it :) .
Thank you very much for your efforts and your great support on this and other issues.
Best regards
Bodil
P.S. Website finished, going to do like this guy for a day or two :laugh:
Congratulations on finishing your project.. it look great :) Always something to smile about when you can walk away from it job done! :)
