1. lembasts
  3. Wednesday, 15 January 2014
I have just started a blog which will contain programming code. I saw a site called "hilite.me" which allows me to paste in my code and it generates lovely looking html. However, when I paste this into a blog article, it looks nothing like the preview. Specifically, the "span" tag needs to start on a new line, and the inline colour style generated needs to override the template. Turning all "span" tags into block level items sounds tricky - I could maybe put in some <br> tags as a workaround, but the colours should be do-able? Am I right in guessing that templates typically use the !important option often to prevent these sort of oveerrides? If not, what could be overriding my inline style colours? Im using the Nocturne template with the Easyblog component and the JCE editor btw...
David
Hi David
The only CSS that could be overruling your inline styling is most likely using the !important option in one of the template/component style sheets. All developers would try and avoid using !important however there can be times when it is simply unavoidable. Would you have a URL to an example of your code with the hilite.me applied?
Thanks - The span colours are working OK. Its the background colour that is ignored - instead of being dark it is light so something is reversing it. The inline CSS on my Div element is as follows:
style="background: #111111; overflow:auto;width:auto;border:solid grey;border-width:.1em .1em .1em .8em;padding:.2em .6em;"
I dont think I can post the sample code as its full of <> and things that would upset this post maybe?
Maybe some code behind the JCE or Easyblog editor is changing the colour of my background?
Found it! The program code was wrapped in a pre element which was wrapped in a div element. the background inline css colour was on the div element. I add the background to the pre element and it worked!
Great... thank you for the update!
