Hello..
Hopefully this will be simple. Do you have css code to reduce vertical space between modules.  For example, I would like to reduce side distance between top-1a, top-1b and top-1c.  The site is not published.  I hope this is a simple task and one I can use to revise for other positions as well.  Thanks
a
