1. JudgeD
  3. Friday, 06 January 2023
I am customizing the J4 J51 Chloe template (under development on a local VM/Windiows/XAMMP) and adding a couple of custom fonts the Business uses. I have web font files (eot, svg, ttf, woff2, woff) and loaded them to the ./templates/j51_chloe/fonts/ folder and added the Font CSS to the enabled ./tempaltes/j51_chloe/css/custom.css.
Although I am unable to see the Fonts in the template_style, topography styling font list to apply to headings.
I followed the Q/A's: https://www.joomla51.com/forum/custom-font-ariana & https://www.joomla51.com/forum/custom-font-cachet-sophia-template
and added custom H1/H2 css styling, but it still does not pick up the custom fonts on the web page (tried 3 browsers for compatibility: Firefox, MS Edge, and Chrome)
Do I need to add alternative H1/H2 custom css styling elsewhere?
Attached image of custom.css
Any help would be much appreciated.
Chris.
Hi Chris
Since you have set important on these CSS rules, they should be applied regardless of the order in which your CSS is loaded (assuming important is not used elsewhere). If you have an online version of the issue I can examine why your fonts are not been applied?
I'll see what I can do about getting it uploaded to a temp site and get back to you.
There is nothing else that needs to be done to ensure the custom.css file is utilised on the site?
I noticed, as I am configuring a Blog/Articles page that in the standard template and the demo installer the style was not applying the same and noticed that the global configuration settings were different. I changed a few settings, but my images still do not apply the same - apart from the global configuration is there other inline styles I need to apply to ensure the formatting is the same?
Kind regards,
Chris
Don't worry about the Blog/Article question - fixed that up with the right menu item category: Category Blog - Alternative. :)
I have a temp website setup (still in dev) - let me know when you are ready to access and I will switch it on.
Let me know where to send the access credentials.
http://joomla-devtemp.australiaeast.cloudapp.azure.com/
Best regards
Chris.
Hi Chris
Could I ask you to check the URL provided as it appears to currently give us a timed-out error. Details for temporary administration access to your Joomla installation can be sent to [email protected]. For our reference please paste a link to this post in your email.
Hey, details were sent and the Website/URL is up.
Thank you Chris
I have copied your CSS to your media folder and replace relative URLs to absolute URLs. Your font appears to be now displaying correctly...
/*! Generated by Font Squirrel (https://www.fontsquirrel.com) on October 29, 2022 */
/*! Template Custom Font Files for YLP */
@font-face {
font-family: 'CelticBold';
src: url(''//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.eot');
src: local(''),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.eot?#iefix') format('embedded-opentype'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.woff2') format('woff2'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.woff') format('woff'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.ttf') format('truetype'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic-webfont.svg#CelticBold') format('svg');
font-weight: normal;
font-style: normal;
@font-face {
font-family: 'Celtic-MD';
src: url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.eot');
src: local(''),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.eot?#iefix') format('embedded-opentype'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.woff2') format('woff2'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.woff') format('woff'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.ttf') format('truetype'),
url('//http://joomla-devtemp.australiaeast.cloudapp.azure.com/templates/j51_chloe/fonts/celtic_md-webfont.svg#Celtic-MD') format('svg');
font-style: normal;
h1, h1 a:link, h1 a:visited {
font-family: Celtic-MD !important;
h2, h2 a:link, h2 a:visited {
font-family: CelticBold !important;
Thanks :) did I have the css in the wrong folder to start with, or does it take precedence being in the media folder?
Much appreciated
Chris.
Hi Chris
This has changed with recent versions of Joomla however if you have template CSS in your media folder then it is best to place your custom.css there.
