I would like a login in the footermenu.
I would like the login in the orange part on the bottem of the site. http://www.wijkbladdelindenberg.nl
Is that possible?
Have you tried creating a login module in this area of your site? Navigate to Extensions -> Modules -> New -> Login and set it to the bottom-1a module position.
I have tried that, but I don't like the way it looks.
I would like to have it in the orange line right down the page. The copyright has to go to the left and the login (menu-item) on the right.
If possible ...
One option is to convert your footer menu to a module position (Template Parameters -> Menus tab) and then place your module in the 'footermenu' module position.
