1. rebelojose
  4. Wednesday, 03 January 2024
Dear Ciarán,
using template Kinvara
#1 - I've a problem with content popups, read more button in content give window greyout and cannot close window
>>SOLVED - it is resolved by add custom .css to template, modifying the z-index -- .modal-backdrop.fade.show { z-index: inherit; }
#2 - same problem with click boxes
>>SOLVED - I disable recaptcha and now works.
#3 - and Language Switcher with "menumod-" not working in mobile version:: in offcanvas menu -- when select respective language can't load or select other language
>>Still the error, please help
I try fix bootstrap with jQuery easy plugin but without success
can you check? please
thank you
Jose
  1. https://dev.rebellicatm.com/geo
Hi Jose
Thank Jose
This issue should be now resolved with the following custom CSS..
.dropdown-menu.show {
display: block !important
.slideout-menu .menu li ul {
overflow: visible;
.dropdown-menu.show * {
color: black !important;
margin-block: 0 !important;
padding-block: 0;
Dear Ciaran,
It's funny that when I went to the site to put this custom CSS, I had Joomla update for 4.4.2. and it is working now.
it was not necessary to edit template and insert custom css
:o
regards
All is well that ends well :)
Thank you for the update!
hi Ciaran,
Language Switcher with "menumod-" not working in template Beaumont desktop
I try with custom .css above but without success
Note: mobile version it is ok
  1. https://dev.rebellicatm.com/casamalm
