1. competaweb
  3. Wednesday, 19 December 2018
I am trying to add 3 columns to a drop down menu and have added ' columns-3' to the main menu item (the text separator) which has the sub-items. However, only one column still appears.
I have tried some solutions proposed in other similar questions but without success.
I send access to administrator section. Better if you see and repair?. Thanks
http://casarobleholidays.com/admnistrator
user: removed
passw: removed
By default this feature is not available with our Boutique template however can be easily added by adding the following to the Custom CSS field of your template settings...
.hornav .columns-2 + ul {
-moz-column-count: 2;
-moz-column-gap: 0;
-webkit-column-count: 2;
-webkit-column-gap: 0;
column-count: 2;
column-gap: 0;
width: 420px;
.hornav .columns-3 + ul {
-moz-column-count: 3;
-moz-column-gap: 0;
-webkit-column-count: 3;
column-count: 3;
column-gap: 0;
width: 630px;
.hornav .columns-4 + ul {
-moz-column-count: 4;
-moz-column-gap: 0;
-webkit-column-count: 4;
column-count: 4;
column-gap: 0;
width: 840px;
Hi Ciaran:
I try this before, but is not ok
Hi Ciaran...
I paste the code in css custom and continue with only 1 column
(sorry for my english)
Have you also followed what is detailed in the following article?... https://joomla51.com/tutorials/template-extras/creating-multi-column-dropdown-menus
Yes, Ciaran, i did..... but dont work
Strangely I don't see the columns-3 class anywhere in your source which implies that it may have been added to the wrong field. Could you double check this?
I think is correct
It does appear to be correct. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
