1. bunsworth
  4. Tuesday, 21 June 2016
I need to collapse the Showcase position. I have no need for it and want the menu to move up under the logo. I do not have anything in the Showcase position.
my site in development is at
http://siteground167.com/~bonnieun/expressivedesignsinc.com/interior_designer/
As always, Thanks for your help. I could not find a solution using search or in your tutorials.
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters...
#container_header {
height: auto;
.hornavmenu-bottom {
position: relative;
Alternatively you can simply set the templates 'Header Full Screen' option to 'No'.
