1. robjoomla
  3. Sunday, 09 December 2018
I have tried to install Colette using Quickstart. After installation and I try to view the site it gives me this error
Fatal error: Can't use method return value in write context in /templates/j51_colette/index.php on line 163
Any ideas on how to fix this?
Thank you!
Rob
Hello, can I please get help?
Hi Rob
Thank you Rob
This issue should be now resolved. You are running an old version of PHP on your server. A small change was made to allow for that.
Thank you very much. If I do upgrade my PHP version in the future to version 7 for example - will the website still work?
Hi Rob
There has been no reported issues with running this template with PHP 7.
