1. memphys
  3. Sunday, 30 June 2013
Hi Guys, google have Blacklisted my Website why he detected Malware on the Template. I have bought it. I dont know what i can do now??!! Please help me.. Look at this scan http://sitecheck.sucuri.net/results/www.valentinalikic.com
If i change the Template then is ok.
memphys
Originally we used a 3rd party (Autson Slideshow) module with this extension which was found to have a hidden link back to the extension developer. Although the link has been removed from the version included with your template it is still flagged as malware by some site checks. We have therefore replaced the slideshow with this template with our J51_Slideshow. You should now be able to download the latest version of this template (inc. the new slideshow) from the 'My Downloads' link to the top right of this page.
Ciaran Thank you now Works.
Now I have the problem that the Dropdown menu from Statistiken does not rise submenu.
memphys
Have you since amended this issue as your sub menu now appears to be showing correctly?
I do not understand. I made the new update. And after the update, the drop down menu does not work.
I Have only change the new Template.
memphys
Hello!
I don´t have the malware problem but I have the "drop down menu problem" in Google Chrome.
Is there something to fix that?
Thank you!
Hi Memphys
I have checked your dropdown menu in both Firefox and Chrome and it appears to be working fine. Maybe someone can confirm this for us? Please ensure yo have done a full refresh on your browser (CTRL + F5) after your update.
Hi Jggk
Thank you Jggk
Could you detail for us in what way your dropdown is not functioning correctly. We have tested your site in Chrome and are unable to find any issues.
Hi!
Could be they are using the last version of Chrome, but in Windows XP?
Because they still have the problem.
Thank you!
