1. Radek100
  3. Tuesday, 14 January 2020
could you let me know 2 advices for Chloe template,please.
1)
Is there any way how to change order of module positions? I would like to move Showcase module under Top 1 modules
2)
Where to add alt image of photos uploded to showcase?
1. To do so you would need to edit the templates index.php file directly (../templates/j51_chloe/index.php). locate the following 2 blocks of code (line 111 - 126) and switch them...
<?php if ($helper->blockExists($this, 'showcase-1')) { ?>
<div id="container_showcase1_modules" class="module_block border_block">
<div class="wrapper960">
<?php $helper->renderBlock($this, 'showcase-1'); ?>
</div>
</div>
<?php } ?>
<?php if ($helper->blockExists($this, 'top-1')) { ?>
<div id="container_top1_modules" class="module_block parallax" style="background-position: 50% 0">
<?php if($particle_block == "top1") {echo $particles;} ?>
<?php $helper->renderBlock($this, 'top-1'); ?>
</div>
</div>
<?php }?>
2. What module are you using in the showcase position to display your images?
1) works perfect
2) I am using J51_LayerSlideshow, which was attached with Chloe template.
Best
Radek
Hi Radek
2. Would the title field text suffice or do you wish to have specific control for each item (alt text field in the module settings)?
I would prefer if is possible to control each item with different input.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this possibility further. For our reference please paste a link to this post in your email.
Unfortunatelly my site is still on Xampp on localhost, no online version. :(
