1. ziggy
  4. Friday, 01 March 2013
I just installed Joomla 3.0 with the Chimera template.
I would like to reduce Module Width, like at the home page, i would like to reduce the main module. Check the screenshot and you will understand what i want.
I went to template, chimera, option,
Reduced layout option from 240 to 100 (for test)
and at : Module width
I actived everything and put 10 in all cases.
I saved and refreshed the home page of the website,
Nothing changed
screenshot : http://jeremyto.free.fr/website.jpg
Hi Jeremy
You appear to want to change the template width rather than module width which is not possible with this particular template. The Module Widths as seen in the templates parameters allows you to change the width of modules displayed in rows. By default modules share the space equally for example here, adding your own module widths allows you to set how each row of modules distributes the available space (eg. 50% - 25% - 25% rather than 33% - 33% - 33%)
