1. ziggy
  4. Friday, 22 March 2013
Hey, I've pored through the CSS style files that would seem to affect this (template.css, nexus.css, jstuff.css) but can't find it. I'd like to change the color of the background of the current menu setting on the toolbar in hornav. http://danielbmusic.com/test3/index.php Maybe it's another Custom CSS line or two...?!? I know the color code I want, just need the rest.... Let's see, using Joomla 3.
Thanks again, loving this template...
Daniel
p.s. also, I've noticed that the "Home" link in the hornav extends all the way to the left side where my logo is. Can I adjust that somehow so that people don't inadvertently go to the home page when they're not wanting to?
HI Daniel
To edit the background of your active menu item within your top menu area try adding the following to the Custom CSS field of your templates parameters..
[code type=css]#hornav li.active {background: #324613 ;}[/code]
Where #324613 is your new background color.
Would you have a URL to an example of your 'Home' menu item? Doesn't appear to be present in the URL provided.
Not sure if I'm understanding your question correctly, but I've set the Home menu item to "Featured blog entries" and right now there isn't one.
I put #hornav li.active {background: #324613 ;} in the Custom CSS block, saved and refreshed. It appears to change something (underneath) the blue button, so it ends up looking like a border around the blue. I've looked through all the provided image files and anyplace where there is a color assignment in the css files and can't find anything that changes this blue button.
Other thoughts?
Daniel
Hi Daniel
Try changing the suggested CSS to the following...
[code type=css]#hornav li.active a {background: #324613 ;}[/code]
Hopefully that should work.
Regarding your home menu item may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Ciaráán
That 'a' did it, thanks. Sent an email re: the rest... D
Thank you Daniel
Try adding the following to the Custom CSS field of your templates parameters which will reduce the size of your logo area and padding around your home menu item..
[code type=css]#hornav ul a, #hornav .separator {padding: 3px 12px 8px;}
.logo_container, h1.logo, h1.logo a {width: 130px;}[/code]
Fantastic, worked beautifully! I also added a height: 85 parameter on the logo container. I'm getting a good CSS lesson here, too, so I won't have to bother you so much in the future... ;-)
Best,
Daniel
