1. Tralala
  4. Friday, 16 June 2017
Using now template Harmony gives me problems by tweaking the behavior of that cumbersome thing called Vegas-slide.
Clicking a menuitem always gives an unwanted delay of 1 second.
The code tells me this:
<div class="vegas-slide vegas-transition-fade vegas-transition-fade-in" style="transition: all 1000ms ease 0s;">
But where can I change that 1000ms? It is element.style, but I can”t find it in the template settings.
(site is still locally under contruction)
You will find all the available settings for the Vegas script here... http://vegas.jaysalvat.com/documentation/settings/
These settings can be applied to the following In your templates index.php (../templates/[YourTemplate]/index.php)...
<!-- Vegas Background Slideshow -->
jQuery(document).ready(function() {
jQuery('#container_header').vegas({
delay: <?php echo $this->params->get('headerslideinterval') ?>,
timer: false,
slides: [
<?php
foreach ($headerslideshow as $item) { ?>
{ src: '<?php echo $this->baseurl ?>/<?php echo $item->header_slide_image; ?>'},
<?php } ?>
</script>
Thanks Ciaran,
But unfortunately this doesn't work.
Neither in the existing custom.css nor in the css-field in the template. And yes, custom.css is loaded.
And I tried it added with the classes .vegas-transition-fade, .vegas-transition-fade-in
By the way: there's only one image in the slider.
I'm afraid I have to find where the element.style is added.
A number of ways of changing this. The easiest one to implement would be to add the following to the Custom CSS field of your templates parameters, editing the transition-duration to your own taste...
.vegas-slide {
transition-duration: 500ms !important;
