1. ksawon
  3. Tuesday, 25 February 2014
I want to present a catalogue using Category Blog layout. I created articles and created new menu item. I set #Leading Articles to 0, #Intro Articles to 10 and #Columns to 2. Everything looks as expected, but only under Chrome. In Firefox and IE the left column overlaps the right column. Please, check enclosed screenshots.
How can I fix it?
If you want to see it online, you can go to my webpage: http://statuetki3d.pl/statuetki-szklane/statuetki-w-cenie-do-80-zl.html
Nice work :)
Thank you for posting your solution!
Update: I solved the problem in the different way. I wanted to document the changes for future reference and I tried different approach - without deleting. I restored original jstuff.css file and add as a custom code:
.pull-left.item-image { margin: 0 0px 18px 0;}
.blog .column-1 {
padding: 0 14px 0 0;
width: auto !important;
The changes I made are marked in bold.
The second column is still a little bit off to the left, but for my purposes it doesn't rally matter.
It solved the problem under Firefox and IE, but the width of the images under Chrome was reduced (check enclosed screenshots). So I edited class .pull-left.item-image in bootstrap.css removing the left margin. Now it works fine.
Thank you for your help. You are the best!.
We hope to have amended this issue by removing the following your templates jstuff.css...
/*Category Blog Layout*/
.items-row{float:left; margin-bottom:5px !important;}
.column-1, .column-2, .column-3, .column-4{padding:0;}
/* 1 column layout */
.cols-1{display: block; float: none !important; margin: 0 !important;}
/* 2 column layout */
.cols-2 .column-1{width:48%; float:left;}
.cols-2 .column-2{width:48%;float:right;}
/* 3 column layout */
.cols-3 .column-1{float:left; width:31.5%; padding:0px;}
.cols-3 .column-2{float:left; width:31.5%; padding:0px; margin-left:2.2%;}
.cols-3 .column-3{float:left; width:31.5%; padding:0px; margin-left:2.2%;}
/* 4 column layout */
.cols-4 .column-1{width:23%;float:left;}
.cols-4 .column-2{width:23%; margin-left:2.2%; float:left;}
.cols-4 .column-3{width:23%; margin-left:2.2%; float:left;}
.cols-4 .column-4{width:23%; margin-left:2.2%; float:left;}
