1. salinger
  4. Monday, 07 September 2020
Hi Ciaran, please have a look at https://www.red-biz.at/index.php/de/ , the news on the bottom of home site. There is a problem with the last columns , the last line is not visible ... Weird, because in the first column the text is longer as well and this one is visible completely...
Could you please help, thank you.
Marion
PS: found the mistake, pics did not have the same height... problem solved :-)
Great... thank you for the update :)
unfortunately I have to come back again to this matter... I got now idea why, the problem occurred again today...could you please have a look, thank you,
Marion
one more issue with this website... I have installed smart slider 3, but it does not load on module place showcase. it loads fine for example on base 1a. unfortunately I can not use your layer slider, as I need more paragraphs in the text...
thanks so. much,
Marion
Hi Marion
.owl-wrapper-outer {
height: auto !important;
For your slideshow issue, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Ciaran, perfect!!!! :D :D :D :D
