1. Mol4
  4. Wednesday, 11 September 2019
On my clients test website I like the header background color (when you scroll down a little) to be somewhat transparent.
I try to achieve this in de custom.css file with the following rule:
.is-sticky #container_header {
background-color: rgba(0, 90, 150, .8)!important;
Unfortunately this doesn't work because an inline class is leading.
How can I manage to change this to what I want?
Thanks!
Thanks, this works, you're the best!
To resolve try adding your CSS to the Custom CSS field of your template settings instead of your custom.css. This should get you around the cascade issue.
