1. Juunas
  3. Tuesday, 20 January 2015
Hi!
As the topic says the mobile menu does not show at all when converted to mobile resolutions.
I acted according to the Calibra template note:
"Converting menu to a Module Position
When creating a menu module for the hornav module position ensure to add moomenu to the Menu Tag ID field of your modules parameters. This enables the animated dropdown menu as seen on our template demo.
If creating a multi-language site a duplicate menu module needs to be created for the responisve mobile menu. Duplicate each language menu module setting the position to hornav-mobile and set the Menu Tag ID to mobile."
Thus created menu modules and set the ID's and positions.
My Joomla version is 3.3.1. Used Chrome, Firefox and Safari latest versions to confirm the problem.
The site is currently in development mode, so I will send super user credentials by request.
Would be extremely glad for help in this issue. :)
Hi Juunas
Have you made any changes to the templates core files? We have installed the default Calibra template along side your current template and it appears to be working without any issues.
Hi!
Seem's to be working now. The cause might have been core file changes. These files have been touched so long ago that I cannot remember.
Thank you very much for your help. I'll just use the fresh template and work on that from now own. Plus karma!
