1. barkin
  3. Monday, 24 November 2014
When editing an article, clicking the "calendar" popup button for either the CREATED or PUBLISHED date does not work so it is impossible to select a date when creating an article. This is the same result on the front-end and back-end. I can put it in manually but it needs to be formatted correctly which is a pain in the butt.
I tried installing another template and the popup button worked immediately so it definitely seems template related.
I have also tried with 3 editors and has the same result.
*** Also, just noticed the "hamburger" mobile menu in top right corner when the responsive template kicks in, is NOT showing as well. Thinking there is some kind of javascript conflict but can't begin to know where/how to troubleshoot.
Could you detail for me the process you go through to encounter the calendar issue?
Regarding the mobile menu issue mentioned in your email.. we have disabled jQuery in your slideshow modules parameters as the jQuery library is already loaded by Joomla 3 which appears to have resolved the issue.
