Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. DSWrights
  4. Tuesday, 28 November 2017
I'd like to add another downlonking arrow on the landing hompage. There is one directly after the Header and when you click it is scrolls down a bit. I'd like another one for the scroll lazy People. Can you help?
You should be able to recreate this element with the following HTML markup...
<a class="scroll-button scrollto" href="#content">
<i class="fa fa-angle-down"></i>
</a>
Sorry, that doesn't help me. I know the code, but I don't know where to put it.
Also, that just automatically scrolls down the page the second the page is opened.
This really depends on where you would like the arrow to appear?
Ideally at the "Module Content Bottom-B" position, where the "#content" area ends, to Show the "Module Bottom-1" area, ideally there would be another one which then Shows the "Module Bottom-2" area.
again, the Code you've posted earlier will ony automatically scroll down. the code needs a condition, like the origial code, otherwise it will simply scroll to the end:
<?php if($header_full == '1') { ?>
</a>
<?php }?>
The condition is to check if the header is set to full screen. If you are to use this code elsewhere, you would have real need for it. Using a 'custom' you can add the arrow to the module position of your choice. I would suggest using the CodeMirror editor when handling raw HTML like this.
